Hear your TV at whatever volume you want
Watching TV at home is supposed to be an easy stress reliever. But it’s hard to relax when your roommates or family tell you to turn it down. Sometimes, they make you turn it down so low you can barely hear anything.
Sure, you could mute it and turn on subtitles, but then you’re missing a ton of dialogue and music. If you want to listen to the TV without disturbing others, you know it’s not an easy task. That’s especially true if you’re hard of hearing.
Speaking of which, here’s a quick tech tip: Tap or click here for Google apps that can help the hard of hearing. Here’s another accessibility tip for your TV. Just follow these steps so that only you can hear the TV’s volume.
So you like the TV’s volume loud. Here’s how to silence the critics
You can pair your TV with a Bluetooth headset if your TV has Bluetooth. Tap or click here for 10 of the best Bluetooth speakers you can buy.
My roommates used to complain about my TV being too loud. Then I purchased these wireless headphones. Now I don’t have to tense up whenever the bedroom door opens in fear of chastisement.
To connect your TV to a Bluetooth device like the one above, follow these steps:
  • Select Menu.
  • Head to Settings.
  • Select Network.
  • Then, select Bluetooth and turn on Bluetooth.
This lets you choose whichever device you want to pair your TV’s audio with.
Or check your streaming device
The Roku app offers Private Listening to stream audio to your phone or tablet. From there, you can use your earbuds or headset. The Roku remote has a headphone jack on the side, so use that to connect.
Here’s another smart option. Wireless gaming headsets are affordable, comfortable and offer excellent sound. Tap or click here for 25 deals on the best headphones, speakers and other audio tech.
Some even come with a transmitter. Make sure the wireless gaming headset you pick supports optical audio for the transmitter connected to the TV.
Tags: Amazon, Amazon Associates Program, Bluetooth, family, Google, Google apps, hard of hearing, home, Roku, speakers, streaming, streaming device, subtitles, tips and tricks, volume, wireless headphones
