5 apps that can clean up your Android in minutes
© Lukman Azis | Dreamstime.com
Everyone loves that new phone feel. For the entire 15 minutes it lasts. Your phone seems to slow down as soon as you start downloading apps and using them to comb the internet.
Performance is essential for everyone regarding their smartphone, considering they help organize our lives. So a slow phone can be a real buzz kill. Tap or click here for seven things you didn’t know your Android could do.
Well, if you own an Android phone, there are several things you can do to fix the problem. Here are apps that clean up your Android in minutes.
Why do I need to clean up my Android?
Whether your phone is running slow or not, keeping your Android clutter-free is essential for many reasons. Over time, unused apps can clutter your phone and lead to glitches and bugs.
RELATED: 8 quick and easy ways to clean up your Android
It’s common to have several unused apps on your phone, and it’s easy to forget they are there. Normal accumulations like downloaded files and caches can affect your phone’s performance. Check out the following apps that will clean your device and speed things up.
1. Files by Google
If you are a Google fan, Files by Google might be the right choice. It offers cleaning recommendations to help keep your phone running smoothly and allows you to browse your files more seamlessly.
The Files by Google app is free, so if you use GSuite, it might be worth having for the ease of finding the correct files.
2. CCleaner
CCleaner is a well-known app that also has a PC and Mac-based option. The real highlight of CCleaner is its user-friendly platform that allows you to optimize your phone with just the tap of a button, but it has a long list of handy features that keep your phone running smoothly, including:
  • Filter old, duplicate and poor quality photos.
  • Delete photos from private chats.
  • Identify which apps are draining your battery and delete them.
3. Smart Phone Cleaner
Smart Phone Cleaner is similar to CCleaner in that it can help optimize storage and delete unnecessary files but it has a few unique features. One example is its app hibernation feature that identifies apps that consume large amounts of battery and temporarily disables them to save battery life.
4. 1Tap Cleaner
For those who don’t enjoy technology or find it challenging, 1Tap Cleaner is an app you should download. Its key features, including cache and phone call log cleaners, are available with a one-tap option. Open the app, tap what you want to clean, and presto, all done.
Its simplicity gives it an edge, and if you expect it to come at a hefty price, you can take a deep breath. This app still comes at the tremendous cost of free.
5. SD Maid
Last but certainly not least on our list is SD Maid. While SD Maid does offer a free version, you’ll need to upgrade to premium to access all of its optimization features.
You can scan your device for all its services, and a detailed list of what you can do will pop up. Choose to use any of the recommended features or just a particular one. Its corpse cleaner feature is quite popular. It finds unused files and eliminates them to give you a speed boost.
You may also like: 8 hidden Android features you should be using
Tags: Android, apps, battery/batteries, bugs, clean up, Cleaner, Files by Google, glitches, Google, optimization, performance, phones/smartphones, speed boost, upgrades
