6 ways tech can solve life’s little annoyances
Minor tech annoyances can seem small at the moment. But in the grand scheme of things, they can cause stress and wasted time. If you don’t want tech issues to have a significant impact, cut them off with these tech life hacks.
They can even help you when you’re away from your computer. Read on for a few easy ways to make your life easier.
This tip is brought to you by our sponsor, TotalAV, Kim’s pick for antivirus and antimalware security. Protect your devices for just $19 for the first year at ProtectWithKim.com.
1. Stop missing important emails
Most email providers let you turn on alerts. This way, you know immediately whenever an email comes in. You may read this and think, “I get too many emails. If I turned on alerts, my phone would constantly blow up!”
Hold on a second. You can turn on alerts for specific email addresses. This way, you’ll never miss an email from an important contact.
Using Gmail as an example, here’s how to use this feature:
Follow these steps on your iPhone, iPad or Android:
- First, open the Gmail app.
- Tap Menu > Settings.
- Select your account.
- Then, tap Email notifications > High priority only.
2. Stop forgetting what you need at the store
Always forgetting that one thing at the store? Have your phone remind you to pick it up when you walk through the door. Make a shopping list in the notes section of the Reminders app on your iPhone. Here’s how:
For iPhone:
- Open the Reminders app.
- Tap + New Reminder, then type your reminder.
To add a location, tap the Location button to assign a notification based on your location. Select one of the options provided or tap Custom to add your location, choose whether you want to be notified when arriving or leaving, and set the perimeter of your reminder area.
To receive location-based reminders, make sure that Location Services is turned on. Open the Settings app, tap Privacy & Security > Location Services and turn on Location Services.
For Android:
You must enable your GPS and location services if you have an Android. This lets you set up a location-based reminder with all your grocery items. Here’s how to make your Android remind you of what you need when you’re at the store.
First, say, “Okay, Google. Remind me to pick up milk, steak, eggs, cheddar and broccoli from the store.” (Substitute this list with whatever you need, of course.)
Google Assistant will ask, “What time do you want to be reminded?” Tell it to remind you when you get to the store — and don’t forget to include the location. For example, you can answer the question with, “When I get to Fry’s on Bell Road.”
Now that you set your location-based reminder, you don’t have to worry about forgetting your list. Once your Android picks up your location, it sends a notification with all the items you want.
3. No more fumbling with the light switch
Have your lamps turned on by setting up a schedule or your location when you’re close to arriving home. All you need are smart light bulbs or plugs and an Amazon Echo device.
First, you have to pair the devices with your phone’s Alexa app
This means you have to create a group. Open the Alexa app and select Devices. Next, hit the + sign at the top-right corner > Tap Add Group > Create a room or device group > Next.
This takes you to a page called Name the room or device group. You can pick one name from a list — or create your own. Just scroll down to Custom Name and type in the group’s name. (You can get pretty creative here.)
Now, it’s time to add your devices. Select the ones you want to group and hit Next > Skip > Done. Alexa is now connected to your light switches.
Second, here’s how to create a schedule so your lights switch on at specific times
Open your Alexa app and hit More > Routines > Hit the + sign and name your routine. Then, you can start setting up the actions. Do this by tapping the plus symbol next to When this happens.
Select Schedule. You have three options: You can set your switch to turn on at sunrise, sunset or a custom time. Choose the schedule and hit Next.
Then, tap Add action > Smart Home > All devices > Select the light switch you want to pair to the routine. Let the app know if you want it to power on or off. (There’s a toggle you can move over.) Hit Save and the routine is finally complete.
4. Stop squinting at the phone screen
Just make your text bigger! On an iPhone, go to Settings > Accessibility > Display & Text Size. Next, tap Larger Text. Slide the toggle next to Larger Accessibility Sizes to the right to enable it. A slider at the bottom of the screen lets you increase or decrease the text size.
Now, apps that support Dynamic Type will adjust to your preferred reading size. This is a lifesaver if you’re like me and love reading news articles from your phone.
Here’s what to do if you have an Android. Open your device’s Settings app and select > Accessibility > Text and display > Select Font size. Adjust the slider to pick your perfect font size.
5. Know precisely where you parked your car
If you have ever wandered around a parking lot searching for a car, this one’s for you. Google Maps will help you find your parking spot easily — and automatically.
On iPhone:
- On your iPhone or iPad, open the Google Maps app.
- Tap the blue dot that shows your location.
- Tap Save parking.
Your parking location will be saved in Google Maps until you remove it.
On Android:
- On your Android phone or tablet, open the Google Maps app.
- Tap Save parking.
When you’re ready to find your car, open Google Maps and you’ll see a pin called You parked here. Tap it and select Directions to make your way back to your vehicle.
If you use Apple Maps, you must turn on Significant Locations by tapping Settings > Privacy & Security > Location Services and System Services > Significant Locations. Here’s what it will look like on your phone:
Return to Settings and open Maps. Turn on the switch for Show Parked Location so it looks like this:
Apple Maps will remember where you parked. When trying to find your car, open Maps, tap the search field and type Parked Car. You’ll get directions to your vehicle. Happy driving!
6. Have all your essential documents on hand
We saved the best for last in this list of tech life hacks. Use the Notes app on an iPhone to scan documents to have them ready when needed. This includes insurance policies, VINs and more. Kim recommends keeping a photo of your license plate handy, too.
If you’re using an Android, you must use a third-party app. Luckily, Adobe Scan is a great resource you can get for free.
Let me leave you with one final tech tip. Here are a few more ways to scan photos and documents without buying a scanner.
Bonus: Protect yourself from the huge annoyance of malware
Cyberattacks are on the rise, and the more we rely on our devices for work, school and our personal lives, the more we have to lose. Whether it’s bank accounts, personal data, photos or conversations, there’s just so much to preserve and protect. That’s why we recommend TotalAV.
TotalAV’s industry-leading security suite is easy to use and offers the best protection in the business. It’s received the renowned VB100 award for detecting over 99% of malware samples for the last three years.
Not only do you get continuous protection from the latest threats, but its AI-driven Web Shield browser extension blocks dangerous websites automatically, and its Junk Cleaner can help you quickly clear out your old files.
Right now, get an annual plan of TotalAV Internet Security for only $19 at ProtectWithKim.com. That’s over 85% off the regular price!
Tags: accessibility, Amazon, Amazon Echo, Android, antivirus, Apple, Apple iPhone, applications (apps), devices, Gmail, Google, Google Maps, hacks, important emails, internet, malware, Notes app, parking, reminders, scan documents, schedule, security, settings, Shopping List, stress, Tech Life Hacks, Text Size
